2001 Peugeot 306 noice
2001 PEUGEOT 306
JAMES09
Engine Mechanical problem
2001 Peugeot 306 6 cyl Front Wheel Drive Automatic
hi, the engine light wont go off and not sure what the poblem is? and dont want to drive the car
Aug 26, 2010 at 5:54 AM
  • 31,937 POSTS
Hi there,
This is a visual warning that there is a set fault code that needs to be investigated, you can drive the car, this should not be a problem, if the problem is some what sever it will go to limp mode, go see your local dealer and get a diagnostic scan done, this will tell them the actual code and with this they can repair what is required.
mark (mhpautos)
Aug 26, 2010 at 6:43 AM
