1996 Peugeot 106 starting intermittently
0197NICK
  • 1996 PEUGEOT 106
  • 4 CYL
  • MANUAL
  • 98,000 MILES
Hi my car will not start on the key it turns over fine but no spark and no fuel to the carb? However it will bump off? Iv alredy checked fuel pump which is working fine also new coil pack new carb and bypassed the ingnition il fresh out of ideas? After the car has been bump started and run for half hour or so it will start on the key! Confused. Com any ideas? Many thanks nick
Thursday, June 10th, 2010 AT 1:34 PM
DAVE H
  • 13,384 POSTS
Hello. thanks for the donation .. much appreciated
You must have a bad/loose ground/earth wire or power wire somewhere ? .. if you have no spark or fuel going to the cylinders it should not start even when jumping/bumping ?
https://www.2carpros.com/forum/automotive_pictures/266999_266999_smiley5_8_3.png
Wednesday, June 16th, 2010 AT 4:37 AM
