Perfectly good running car until yesterday.
74,146 MILES • 5.0L • V8 • RWD • AUTOMATIC
THOMAS MCSHAN
The vehicle was 2quarts low on oil and I
Drove it to the auto parts store with hesitation on take of intermediately. Got the oil in and it wouldn't start got it towed home investigated and discovered a clogged fuel filter. Replaced it and it will only start in neutral and when put in gear it stalls unless the gas pedal is idled up. And there's a rough take off and it's smooth once it gets going. Stalls in reverse automatically.
Mar 19, 2017 at 7:37 AM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and iac hole with choke cleaner. if it continues check fuel pressure with a gauge it may be low causing this. see link.
Mar 20, 2017 at 12:35 AM
