PCM replacement?
130,000 MILES • 4.6L • V8 • FWD • AUTOMATIC
NBHOWARD86
I need to know if I should replace the PCM in my 98 Lincoln Continental. It will drive for about 30 to 45 minutes and then the check transmission light will come on, once I turn the car off and turn it back on it goes away and I can drive for another 30 minutes or so. It recently just started randomly stalling out at stoplights and the RPMs were dropped really low. I was thinking it may be the idle sensor, but the other problems obviously point to something bigger. Please help if you can!
Apr 8, 2016 at 10:23 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it.
Apr 8, 2016 at 11:43 PM
NBHOWARD86
That's the thing is I can't read the engine codes. every time I hook up the computer it tells me that it can't read it, and throws generic codes up. Any other ideas?
Apr 14, 2016 at 9:48 AM
HMAC300
  • 48,601 POSTS
then have it checked for a poor connection someplace either at connection or if you have an adapter check that. it may be a wire problem and check for a blown fuse under hood.
Apr 14, 2016 at 11:37 PM
