Parking gear
2004 CHEVROLET CAVALIER
86,111 MILES • 6 CYL • 2WD • AUTOMATIC
BONNIE98
I went to take my car out of park, and put it in drive, I had to force the parking gear, out to get it into drive, all other gears are fine, like drive, reverse, low, all others, I got it out of park, went to check on my brother, could not get it back into park, so I could shut it off, finally I was able to get it back in park.
Jul 25, 2016 at 9:51 AM
HMAC300
  • 48,601 POSTS
it may be a shift interlock problem make sure brake pedal is pushed down from removing it from park, otherwise it may need an adjustment or the cable has stretched. Have a local mechanic take a peek at this.
Jul 25, 2016 at 12:02 PM
BONNIE98
Thank you so much, I will have a person look into this, I wanted also so I could be sure of my car, give you my VIN number. 1G1JC12F947282115
Jul 25, 2016 at 1:26 PM
HMAC300
  • 48,601 POSTS
we do not need the VIN thanks. make sure to check fuses as that may be the problem as well. it is fuse ERLS on left hand side of dash.
Jul 25, 2016 at 3:09 PM
