code P1589
50,000 MILES
PKYM
Hello, I have a Toyota Voxy "though I had to fake the name to Corolla since I can't find it on the brand list " . pops up a check engine light after it has start moving. i used my car code reader to clear the dtc code which was P1589 but the problem is still there. What might be the problem?
Feb 16, 2020 at 2:38 AM
  • 110,251 POSTS
The vehicle isn't offered in the US, so mu technical info is very limited. However, I will try to help.
The code deals with the throttle control system. Has anything been worked on recently? What is the vehicle doing?
Feb 16, 2020 at 8:11 AM
PKYM
I replaced a CVT chain from there the car started jerking when shifting from park to drive ,drive to reverse and vice versa but there was no check engine light. I cleaned all sensors allocated on the gearbox after that the jerking disappeared but the check engine light popped up. I cleared the fault and the check engine went off. After driving for like 2 miles the check engine popped up again.I checked the faults code on my obd code scanner and it was P1589 "acceleration sensor learning value ". i have tried to clearer the code but after driving for about a distance of one meter the check engine light come on again. What might be the problem?
Feb 16, 2020 at 9:54 PM
  • 110,251 POSTS
I suspect the system needs to complete a relearn procedure. I hate to say it, but I don't have it for this vehicle. By chance, do you have a contact where you are located that can do it for you?
Feb 17, 2020 at 5:11 AM
PKYM
Nah, I have tried to ask my work mates and no one has the idea.
Feb 18, 2020 at 11:34 AM
PKYM
  • 110,251 POSTS
I wish I had a better answer for you. However, I can't be sure, but I suspect that is what needs done. You may have to see a dealership.
Feb 18, 2020 at 12:19 PM
