p0500 code speed sensor issues
1999 TOYOTA AVALON
ERICJAMES
im having issues with my speed sensor. the speedometer and odometer do not work and check engine light gives the p0500 code for the speed sensor, I have checked fuses, replaced speed sensor and still did not work. I also tried slaving in a instrument cluster and even a ECM. and still no change. I check the wires to make sure there is no break from the harness to the computer. at this point I have no other ideas...PLEASE HELP
May 26, 2013 at 5:59 AM
KHLOW2008
  • 41,814 POSTS
Check the VSS driving gear and ensure it is not worn.
May 26, 2013 at 10:52 AM
ERICJAMES
its just a magnetic sensor that reads revolutions..no gears
May 28, 2013 at 1:15 AM
KHLOW2008
  • 41,814 POSTS
The part that is plugged into transmission, not the sensor.
May 28, 2013 at 1:30 AM
