P0452
1999 SATURN SW2
100,800 MILES • 4 CYL
LEANORD1
I scaned my car snd got a code p0452 of the tank pressure sensor? Is that would i need to eliminate the code or is there more to buy so in repair it myself!
Apr 14, 2016 at 2:20 PM
CARADIODOC
  • 34,381 POSTS
P0452 - Evaporative Emission Control System Pressure Sensor Low Input
Diagnostic fault codes never say to replace parts or that one is bad. They only indicate the circuit or system that needs further diagnosis or the unacceptable operating condition. Reading the codes is just the first step in diagnosing the cause of that code. The most common cause for this type of code is an open circuit, meaning a break in the circuit. Start with a visual inspection of the wires, then look for corroded or stretched connector terminals. The sensor itself should be the last suspect after everything else is ruled out.
Apr 14, 2016 at 2:37 PM
