P0300
103,000 MILES • 6.1L • V8 • RWD • AUTOMATIC
ROBERT L. KILEY JR.
My car is the SRT8. Just put on new coil packs and new plugs and still have code P0300. Need to know what to change next?
Jul 16, 2017 at 3:31 AM
CARADIODOC
  • 34,415 POSTS
Changing random parts is the most expensive and least effective way to diagnose a problem. It would cost less to take the car to a mechanic.
Code 300 is for a random cylinder misfire. All of the cylinders are involved, but you know every ignition coil and every injector did not fail at the same time. Look at the other things each cylinder has in common. Most notably that is fuel pressure, fuel quality, and air/fuel mixture. A scanner will let you view live data to see how the oxygen sensors are switching between "rich" and "lean".
A vacuum leak is another good suspect. Chrysler is the only manufacturer that never needed a mass air flow sensor to make their engines run right, so problems associated with those are not an issue, but you can still get a lean misfire, and a vacuum leak can affect all of the cylinders.
Jul 16, 2017 at 12:46 PM
