P0299 (boost pressure regulation: control range not reached)
77,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
NICHOLAS YARBROUGH
I just got this code from the check engine light. Any ideas of where I should start looking? I am hearing looking at the turbo connection to the intake. Also, I have one last problem that just occurred. When I reverse I hear and feel a decent amount of rattling. It sounds like it is coming from under the hood. I was told that it might be mounts for the engine?
Sep 18, 2016 at 9:04 AM
SATURNTECH9
  • 30,868 POSTS
It could be a mount with the rattle noise or the exhaust heat shield what is the VIN number?
Sep 18, 2016 at 11:37 AM
NICHOLAS YARBROUGH
WVWFD7AJ4BW088985
Sep 18, 2016 at 12:53 PM
SATURNTECH9
  • 30,868 POSTS
Do have a lack of power?
Sep 18, 2016 at 2:20 PM
SATURNTECH9
  • 30,868 POSTS
I would remove the pressure booster sensor and see if the diaphragm is torn.That is a common thing that happens. also, inspect all the turbo and inner cooler hoses. If it has had a front end damage it could have a cracked inner cooler.
Sep 18, 2016 at 2:53 PM
NICHOLAS YARBROUGH
Could I get a diagram of where the booster is and the turbo is located?
Sep 21, 2016 at 12:51 PM
SATURNTECH9
  • 30,868 POSTS
The turbo is on the back of the engine it's round and pretty big should be easy to spot.The boost pressure sensor is by the radiator and inter cooler it's in the hard plastic inter cooler pipe.I was mistaken that one doesn't have the diaphragm that tears.
Sep 22, 2016 at 10:46 AM
