P0268 and how to repair it.
187,000 MILES • 2.7L • 6 CYL • AWD • AUTOMATIC
MARKANDBOO
New injector was installed today, now OBD code is p 0 268 high voltage in circuit, how do I repair it?
Aug 27, 2015 at 10:20 AM
  • 110,251 POSTS
First, you may have gotten a bad injector.
Since the injector is new, dirt shouldn't be an issue. Therefore, start by checking the fuel injector 3 harness for an open or shorted wire or connection as well as the number 3 circuit poor electrical connection due to corrosion.
NOTE: I assume that the number 3 injector is the one you replaced.
Aug 28, 2015 at 2:01 PM
