P/S SIGNAL
76,000 MILES • 2.5L • V6 • 2WD • AUTOMATIC
IRANGI
Hi, after the days work yesterday I parked my car and this morning when I started the car a P/S sign appeared on the dashboard and the steering wheel was stiff, the system seems to be electric since I can't find the P/S fluid pump, what could be the problem and what's the possible solution?
Mar 9, 2016 at 5:24 PM
WRENCHTECH
  • 20,760 POSTS
You will need a dealer level scan tool to access the control module for that and there should be some codes. You could test all your fuses with a test light in the meantime.
Mar 9, 2016 at 9:20 PM
