overheat, rpm up and down, engine oil decrease
60,000 MILES • 3.0L • 3 CYL • 2WD • AUTOMATIC
HASHIM829
sir, my car overheat,though there is no gauge of heat but its body and engine seems to be like fire. Engine oil i using is 20w 50,engine oil level on dipstick showing a level of half as i driven to 200 km approximately. Also, at idle position rpm comes down and when i increase rpm through pedal on idle, car switch off when i release paddle. Please help and advice where is the problem. Really helpful for your advice.
May 19, 2017 at 12:12 AM
  • 55,694 POSTS
This sounds like a problem with the exhaust system being plugged. I would check the catalytic converter first.
Here is a guide that will help you see if that is the problem.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Cheers, Ken
May 22, 2017 at 3:50 AM
HASHIM829
Thanks for your reply Ken.I checked with mechanic and he said that its gasket blown.I placed new head gasket set,changed filter,new spark plugs.Now car pickup increase and no overheat issue,but it is giving same fuel average which was before,around 10km/l.How to increase fuel average?
Jun 26, 2017 at 8:13 PM
  • 55,694 POSTS
Try disconnecting the battery for a couple of hours to see if the system resets. Then drive it for a while to see the new average.
Jun 27, 2017 at 4:10 AM
HASHIM829
Thanks Ken,will let you know.
Jun 28, 2017 at 5:17 PM
  • 55,694 POSTS
Please do :)
Jun 29, 2017 at 3:48 AM
HASHIM829
on longe route,it is giving good mileage but not smooth ride,with same acceleration feel like someone apply brake and then again it picked acceleration,this happen time to time with same acceleration.
Jun 29, 2017 at 6:06 PM
  • 55,694 POSTS
It almost sounds like you have an engine misfire. Here is a guide to help you confirm the problem and get it fixed.
Cheers, Ken
Jun 30, 2017 at 3:52 AM
