Overheating while driving
206,164 MILES • 2.3L • 4 CYL
PAUL DREHER JR.
  • 10 POSTS
Well here we go, my car overheats while driving the car. no A/C on just driving at highway speeds. If I turn the heat on it cools back down. What could be the problem? I thought maybe condenser not letting air flow to radiator.
Mar 27, 2019 at 7:55 AM
  • 110,248 POSTS
Welcome to 2CarPros.
If there is any debris that is blocking air flow, that would be my first suspect. If turning on the heater helps, make sure the coolant level is full. If it is, then I would suggest flushing the radiator and engine block. Since it does cool down with the heater on, that tells me it isn't related to a bad or sticking thermostat. And, since it happens at highway speed and not around town, that leads me to believe there is a restriction in the system. Also, keep in mind that a leak or faulty radiator cap can cause issues too. Make sure nothing is leaking and that the cap is good.
With that, clean any debris that could block air flow. Also, confirm the coolant is clean and full. If that checks good, then try flushing the system to see if that helps. If you flush the system, I would also replace the thermostat at that time just as preventative maintenance. If it still doesn't, we will need to check for a possible head gasket issue.
Here are a few links that you may find helpful:
https://www.2carpros.com/articles/coolant-leak-symptoms
https://www.2carpros.com/articles/car-is-leaking-coolant
https://www.2carpros.com/articles/symptoms-of-a-bad-water-pump
Here is a link that shows how to pressure test the system. Most parts stores will lend or rent you the tool to do this.
https://www.2carpros.com/articles/radiator-pressure-test
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
And I hope we don't need this one:
Mar 27, 2019 at 1:30 PM
PAUL DREHER JR.
  • 10 POSTS
I also need to add when it is cool outside it does not get hot.
Mar 28, 2019 at 7:52 AM
  • 110,248 POSTS
Welcome back:
If the engine doesn't warm up when it is cold outside, then chances are the thermostat is sticking open. Is that what is happening? Is the engine not warming up or do you mean you get no heat inside?
Let me know,
Mar 28, 2019 at 10:38 AM
PAUL DREHER JR.
  • 10 POSTS
No, when it is cool outside it doesn’t run hot it stays in normal temperature range.
Mar 28, 2019 at 1:29 PM
  • 110,248 POSTS
Welcome back:
With that, just make sure the coolant is full. If it is, then I recommend the flush.
Mar 29, 2019 at 1:23 PM
