My girlfriends car overheated I picked her up and took a look at the car and when I topped up the coolant I noticed it was not clear. It looked rusty and was not see through.
Initially I topped up the coolant and turned on the car to see what the problem was, then after about fifteen minutes the car started steaming out of the top of the radiator cap and the surge bottle overflowed. The radiator fans did not turn on.
I drained the radiator and changed the thermostat but this did not fix the problem. Fans now kick on at about 75% to hot but the coolant still seems to have some milky residue.
I am not sure the car has an oil cooler, otherwise this is there a way to check to see if this is transmission oil vs engine oil?
Sep 18, 2017 at 2:53 AM
