Overheating
170,000 MILES • 3.3L • V6 • AUTOMATIC
WENDLE1214
I have recently changed the radiator and fans. New spark plugs and injectors. Recently put in a new thermostat. I have ran a combustion check to check for a head gasket but did not show no sign. I am losing all my coolant but do not see from where. The car runs great just the temperature goes up. What can it be?
Sep 21, 2017 at 4:08 PM
MIKE H R
  • 3,094 POSTS
coolant will either burn or leak, you said you did a compression check. Was that on the cylinders or radiator? some times when putting in a new radiator there may be a vapor lock. if radiator does not show any drop in pressure the vapor lock could be the problem, or it is going in to the cylinders.
Sep 22, 2017 at 3:05 AM
