Overheating car
109,000 MILES • 2WD • AUTOMATIC
MADISONPAIGE
My car started to overheat while on a drive the other day. I turned the heater on to expel heat from the engine and the temperature gauge dropped down to the halfway mark. I checked the coolant and it was at a proper level and did not seem dirty or clouded. A day or two later I checked the engine, all the tubes seem fine but I noticed when I turn the car off I can hear liquid moving through the engine (not quite gurgling but still loud enough to notice).
Sep 16, 2018 at 4:44 PM
Good morning.
The first thing I would do is to change the thermostat. It may be sticking closed and causing the engine to run hot.
The noise you hear may be the coolant boiling.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Sep 16, 2018 at 9:49 PM
