Overheating?
1994 CHEVROLET VAN
106,425 MILES • 5.7L • V8 • 2WD • AUTOMATIC
MUFDVE
I changed the thermostat, radiator, and water pump. It is still overheating after I drive it for a while and at stop lights the engine seems to slightly surge up and down.
May 16, 2023 at 5:15 AM
  • CERTIFIED EXPERT
  • 53,872 POSTS
If you've already replaced the thermostat, radiator, and water pump, but your van is still overheating and experiencing surging issues at stop lights, there may be a few other potential causes to consider:
Cooling Fan Malfunction: The cooling fan plays a crucial role in dissipating heat from the radiator. If the fan is not operating correctly or not engaging at the appropriate temperature, it can lead to overheating. Check the fan motor, fan relay, and associated wiring to ensure they are functioning properly.
Air Pocket in the Cooling System: If there is an air pocket trapped within the cooling system, it can disrupt proper coolant circulation and cause localized overheating. Bleeding the cooling system to remove any air pockets may help alleviate the issue. Consult your vehicle's service manual for the correct bleeding procedure.
Clogged or Restricted Cooling System: Even with a new radiator, there's a possibility of a restricted or clogged cooling system. Over time, debris, sediment, or deposits can accumulate within the cooling system, hindering coolant flow. Flushing the entire cooling system to remove any obstructions might be necessary.
Faulty Temperature Sensor: A malfunctioning coolant temperature sensor may provide incorrect readings to the engine control module (ECM). If the ECM receives inaccurate temperature information, it can affect the engine's fuel and ignition management, leading to overheating and erratic engine behavior. Consider testing or replacing the temperature sensor.
Engine Misfire: An engine misfire can cause irregular engine operation and affect the cooling system. A misfiring cylinder can create excessive heat and increase the overall engine temperature. Perform a diagnostic check to identify any potential misfires and address them accordingly.
Head Gasket Issues: Although less likely, a failing head gasket can still be a possible cause. A compromised head gasket can result in coolant leakage into the combustion chamber, leading to overheating and rough engine operation. A thorough inspection, including a compression test, can help determine if there's a head gasket problem.
May 16, 2023 at 12:33 PM
MUFDVE
I replaced the fan clutch and I've done a pressure test but I'm losing pressure, but I have no leaks. I have no water in my oil and also, I was told by the gentleman at the auto parts store that coolant sensors don't have anything to do with my overheating for my year of my van which is 1994.
May 16, 2023 at 1:06 PM
