Overheating
144,000 MILES • V8 • 2WD • AUTOMATIC
TROUBLE1980
  • 49 POSTS
I have a SBC that usually runs around 210/225 oil temperature. I was driving the other day temperature was 222 and shot up past 300 in under a minute. I pulled over shut car off and seen coolant spraying everywhere out of my radiator into my reservoir blowing out of all of the hoses. also once it cooled down for me to pull the radiator cap my coolant looked like rusty chocolate milk. I have no white smoke coming out of tailpipe and no milky residue in my oil compartment. replaced water pump a few days before this happened. Please any help or ideas would help.
Jun 25, 2017 at 2:33 AM
HMAC300
  • 48,601 POSTS
pressure check for leaks like a head gasket or something similar. if it is an external leak it will show up. most auto parts rent this. there is also a chemical tester that you can add to coolant.
Jun 25, 2017 at 3:19 AM
TROUBLE1980
  • 49 POSTS
Thank you HMAC300 I will definitely have this done. And will post results once completed.
Jun 25, 2017 at 6:24 AM
  • 55,710 POSTS
It sounds like a classic stuck thermostat. Here is a guide that will give you an idea on what to do to fix the problem.
Cheers, Ken
Jun 27, 2017 at 8:42 AM
TROUBLE1980
  • 49 POSTS
Hello HMAC300 & Ken.
I solved the problem, after a radiator and block flush it ended up being a short in my fan it would kick on and then after a few minutes slow down or completely shut off but when in park it would run at medium speed, replace fan relay and rewired now works fine.
Jun 27, 2017 at 10:22 AM
  • 55,710 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
Jun 27, 2017 at 12:20 PM
TROUBLE1980
  • 49 POSTS
I absolutely will thank you for all your input and knowledge, as I am kinda car illiterate, just know basic troubleshooting
Jun 27, 2017 at 12:45 PM
TROUBLE1980
  • 49 POSTS
Actually I do have one more question can I run the Sbc with out the thermostat and straight water for the summer? I have a 160 thermostat and my temp runs 210/225 with it without it it runs 185/195 degree
Jun 27, 2017 at 2:14 PM
HMAC300
  • 48,601 POSTS
210 is the normal reading with a thermostat leave it in so emissions will work right
Jun 27, 2017 at 11:25 PM
TROUBLE1980
  • 49 POSTS
OK yea that's what I seen also but didn't know how hot is too hot would 230 be concerning if it got that high?
Jun 27, 2017 at 11:36 PM
HMAC300
  • 48,601 POSTS
well it's coolant and under pressure if working right so if going to 250 /260 is more worry some what you are reading is right by cylinder head anyhow so it's right before it leaves the engine.
Jun 27, 2017 at 11:49 PM
