Transmission not shifting into overdrive
160,000 MILES • 5.9L • V8 • 2WD • AUTOMATIC
METCALFP
My transmission will not shift into overdrive. do I need to replace the transmission and will it damage the transmission if I keep driving it?
Apr 9, 2018 at 12:44 AM
CARADIODOC
  • 34,415 POSTS
Turning overdrive off is a normal condition when pulling a heavy trailer, so that will not cause damage. The place to start is with connecting a scanner that can access the Transmission Computer to see what it is reacting to. In particular, overdrive is typically inhibited until the transmission fluid reaches a specific temperature. If that temperature is incorrectly being reported as too cold, the computer will not allow shifting to overdrive.
Also, look if your truck uses a kick-down cable from the throttle body to the transmission. If it does, those are known for sticking and failing to return under spring tension. That will cause delayed up-shifts at too high a speed, and you may not be reaching the speed needed to overcome that and get into overdrive.
May 1, 2021 at 11:30 AM
