over heating
160,000 MILES
ADI1991
  • 60 POSTS
hi
i have nissan maxima 2000 3.0l,
before few days i changed it's water pump after that i am facing problem of overheating.
every time i found empty coolant reserve tank after running around 20 kms.
engine is clean without any traces of water in it.
May 24, 2013 at 8:25 PM
HMAC300
  • 48,601 POSTS
have system pressure checked for leaks like ahead gasket
May 24, 2013 at 10:56 PM
ADI1991
  • 60 POSTS
How to check the system pressure
Any tool needed
May 24, 2013 at 11:02 PM
HMAC300
  • 48,601 POSTS
yes a special tool is needed but better to have amechanic do it as they have experience in what to look for . you dont'
May 24, 2013 at 11:04 PM
ADI1991
  • 60 POSTS
But sir here in saudi arabia 97% of mechanics dont know anything
So its easy for me if you can tell me how it will be done
May 24, 2013 at 11:08 PM
HMAC300
  • 48,601 POSTS
you need a coolant pressure tester for your car then you pum p it up to about 20lbs on gauge and see if it goes down. if there is a leak you can look at allhoses, connections etc. ifyou see no leakage it is either a head or intake gasket leaking internally.
May 25, 2013 at 3:17 AM
