Loud cranking noise when putting vehicle into gear
140,000 MILES • 0.5L • V6 • 2WD • AUTOMATIC
DANA SOUTHERN
  • 5 POSTS
Replaced the OSS and TSS sensors. After doing so there is still a loud cranking noise when putting vehicle into gear. Once accelerating it takes the car a minute to take off. Any ideas would be appreciated.
Aug 18, 2019 at 8:32 PM
Good morning,
Those sensors have nothing to do with this issue.
Why did you replace them? Were there any codes?
How long since you changed the fluid and filter?
Aug 19, 2019 at 12:51 AM
DANA SOUTHERN
  • 5 POSTS
Codes didn't show up. The passenger side airbag, check engine light, and low tire pressure dash lights were flashing. Replaced sensors after being told it would take care of the problem. The dashboard lights are now fixed. Replaced the fluid and filter yesterday while changing out the sensors. Not long before this the PCM was sent off for repairs and seemed to be working fine.
thanks for your help.
Aug 19, 2019 at 5:37 AM
Okay, is it fixed since the PCM repair or do you still have the issue?
roy
Aug 19, 2019 at 5:42 AM
DANA SOUTHERN
  • 5 POSTS
The PCM repair was the very first thing that was done. It seemed to run fine for a few weeks then that’s when the issues with the lights and gears changing trouble started.
Aug 19, 2019 at 7:21 AM
DANA SOUTHERN
  • 5 POSTS
Do you think it may be something in the transmission? Maybe a noiseless or something? Vehicle doesn’t shimmer at all.
Aug 19, 2019 at 7:32 AM
Did anyone check the battery and the cables for being clean and tight? Dirty battery cables and low voltage are common failures.
Aug 19, 2019 at 7:36 AM
DANA SOUTHERN
  • 5 POSTS
Thank you so much for the information. I will try this and see what happens.
I'll let you know how it goes.
Aug 19, 2019 at 9:44 PM
You are welcome.
Always glad to help.
Keep us updated.
Aug 19, 2019 at 9:48 PM
