1988 Opel Kadett Cold Engine Shakes
OPEL
MAJDIY
  • 5 POSTS
Hi everybody
Iam happy to find you .
I have a car 1988 opel kadet , engin size 1600CC
Iam having a bad problem with my car engin , when the engin is cold its shiver and not stable , its stay like this after the heat height then it back stable , i did try to repair manythings like the engin basments but not solved .
I hope to find here any sugesstion or to know whats the problem.
Thanks
Regards
Apr 9, 2007 at 1:52 AM
MAJDIY
  • 5 POSTS
ok i make donation :)
i hope someone will take care of my problem bcoz iam sick from it .
Apr 9, 2007 at 2:19 AM
BRUCE HUNT
  • 3,754 POSTS
Engine basements - are you referring to the motor mounts? I would suspect them. Given the age of the vehicle, they could be drying out and weak. They may look fine but don't let that fool you.
I would check the egr valve and the pcv.
What you need to determine is whether this is a engine performance problem or a mounting issue.
Apr 9, 2007 at 4:30 AM
MAJDIY
  • 5 POSTS
hi
thank you for your replay .
iam sorry sir , iam not that good in cars english words.
the motor mounts i replaced them with new one but the problem didnt solved the same .
the problem not performance , the motor is strong , but as i told you whenever the motor cold its shiver alot .
Regards
Apr 9, 2007 at 4:57 AM
BRUCE HUNT
  • 3,754 POSTS
I would check the EGR valve and the PCV.
Not a problem, I think I understood you just fine.
Apr 9, 2007 at 9:04 AM
MAJDIY
  • 5 POSTS
Hi
Thanks
Can you please show me a picture for the EGR valve and PCV , iam sorry iam not sure what they mean in my language , if you have a picture or some explain to understand , and i will check them soon
Regards
Apr 9, 2007 at 9:28 AM
BRUCE HUNT
  • 3,754 POSTS
Our books do not cover the Opel but here is a link to a website with generic information and diagram about the EGR valve.
Apr 9, 2007 at 9:51 AM
MAJDIY
  • 5 POSTS
Thank you very much :)
Apr 9, 2007 at 10:50 AM
Suggested Repair
Motor mounts were already replaced without fixing the cold shake. Check the EGR valve and PCV valve next to determine whether the cold idle instability is an emissions or crankcase-ventilation issue rather than a mounting problem.
Conversation Summary
The owner of a 1988 Opel Kadett 1.6 reported that the engine shakes and runs unsteadily when cold, then stabilizes after warming up. The motor mounts were replaced, but the problem remained and the engine otherwise ran strongly. The expert advised checking the EGR valve and PCV valve.
