A code P0440 could mean one or more of the following has happened:
"Â The gas cap is not installed or working properly
"Â The purge solenoid has failed
"Â The canister is plugged and not working properly
Possible Solutions
With a P0440 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
"Â Remove and reinstall the gas cap, clear the code, and drive for a day and see if the codes come back.
"Â Inspect the EVAP system for cuts/holes in tubes/hoses
"Â Inspect for damaged or disconnected hoses around the Evap purge solenoid
"Â Check and/or replace the sensor
"Â Check and/or replace the purge valve
"Â Have a professional use a smoke machine to detect leaks
SPONSORED LINKS
Saturday, July 10th, 2010 AT 11:28 PM
