why is the 2 end spark plugs good and the middle 2 are fine
OLDSMOBILE
FREELOADS77
:evil: :twisted: i got a 94 acheiva (oldsmoblie) and the 2 end plugs are fine but the mittle 2 are fouled out its the ouad 4 :!: . :evil: :evil:
Jul 22, 2006 at 4:40 PM
MIKEYBDMAN
  • CERTIFIED EXPERT
  • 623 POSTS
I would preform a compression check on all of your cylinders. It sounds like you may have a bad head gasket or cracked head between the two middle cylinders. Of course this is worst case senerio.
It could be two bad fuel injectors, or maybe an outside chance of leaking valve seals.
Do the compression check and go from there. If the two middle cylinders are low, pull the head off and see what is going on. May be time for a top end job anyway with it being a 94 model.
Jul 22, 2006 at 5:50 PM
