1997 Old 88 power steering problem
1997 OLDSMOBILE
DOOMER33
Without warning the power steering failed while making a SLOW, sharp left turn. There was no fluid leak, no noise, no vibration- it just quit working. Checked the fluid, which looked a bit low according to the dip stick, and added some more fluid. Still no leaks but still no power steering. Where should I start?
Jul 3, 2007 at 1:21 AM
TROYANDERSON13
  • 9 POSTS
[quote:75c96260ab="doomer33"]Without warning the power steering failed while making a SLOW, sharp left turn. There was no fluid leak, no noise, no vibration- it just quit working. Checked the fluid, which looked a bit low according to the dip stick, and added some more fluid. Still no leaks but still no power steering. Where should I start?[/quote:75c96260ab]
i would guess the power steering pump went. its located on the belt routing
Sep 22, 2007 at 5:40 PM
