1996 Other Oldsmobile Models security
1996 OLDSMOBILE
60,000 MILES • 6 CYL • FWD • AUTOMATIC
KJKINDNESS
this car has 3.1 v6, starts and runs great from a cold start. After the car has been shut down after a ten or more mile trip it either refuses to start or starts then chugs, shakes knocks shakes and dies and will not restart. If left for 30-40 minutes will start but needs coaxing to keep runnning, if you get it to rev above 2000 rpm for a minute ro so it will setle down and run normaly. After replacing the iac valve which was broken, problem prevailed. Then replaced tps maf sensor and the ignition lock & thermostat.The (used) ignition lock seemed to solve the problem until the return of warm weather and began acting up again. Put in a new ignition lock this time. This car leaves us stranded everywhere. Last fall I manages to get it towed to a friends garage while it wouldn't start and we scanned it and got security fuel injector shut off. Otherwise the car had no codes before. reset code and car started fine. Have recently scanned after it srarted having this problem but no codes. Seems to be related to outside temp somehow. When the rough start happens the secuity light is flashing. Any ideas? Keith
Apr 26, 2008 at 8:58 PM
2CARPRO JACK
  • 11,533 POSTS
Have you done a relearn on the pass-key?
GM PASS LOCK RELEARN- Ignition to "run" position, try to start and let key return to "run" position
Approx ten minutes security light will go off
Turn key "off" and wait 5 seconds
Repeat 2 more times for a total of 3 relearns.
Turn key off, then start it
Also be sure there are no other scannable items on your key ring (Mobil Speed Pass...etc)
Apr 27, 2008 at 1:09 AM
