1994 Oldsmobile turn signal flasher
1994 OLDSMOBILE
CUTIESUSI
Electrical problem
1994 Oldsmobile V6 Two Wheel Drive Automatic 152000 miles
The turn signals on my sons 1994 Olds Achieva are not working. I have checked the fuses and am guessing that it is the flasher. Here's the thing, I've looked all around the control/fuse panel and can't seem to find the flasher........where is it located on this model???? Also do you by chance know if it's a 2 or 3 prong?
Dec 6, 2007 at 8:37 AM
  • 75,988 POSTS
Its behind the left side of dash, right of steering column. There's 2 of them, the defogger relay and the turn signal flash unit. Unable to give you in picture for an illustration wish I could sorry.
Dec 6, 2007 at 8:49 AM
CUTIESUSI
I was told that the turn signal flasher unit is a silver cylinder with either 2 or 3 prongs - is this correct for a 1994 Olds Achieva???? Can't locate anything like that under the dash????
Dec 6, 2007 at 9:13 AM
  • 75,988 POSTS
My references says its there-for the color now a days they can be silver cylinders and plastics.
Dec 6, 2007 at 9:43 AM
