1993 Other Oldsmobile Models Coolant/ Antifreeze leaking
SPAZZBRINK
  • 1993 OLDSMOBILE
  • 6 CYL
  • FWD
  • 98,000 MILES
I have a 1993 Olds Cutlass Supreme with a 3.1. I'm having a problem with my coolant leaking. When I open the hood about 3 weeks ago from it overheating I noticed the coolant was full but also noticed that there was coolant leaking on to the serpentine belt. I think it is coming from the water pump but I'm not sure. Do you think it could be the whole pump or just a gasket, and how much does a repair like this normally cost?
Wednesday, December 30th, 2009 AT 10:43 AM
HMAC300
  • 48,601 POSTS
This needs to be properly diagnosed as there were problems with intake manifold gaskets. If it's gaskets it can be about $800 to fix it, but it coul be a waterpump as well. Apro can pressure check he system to see where it can bee seen where it is leaking.
Friday, January 22nd, 2010 AT 2:34 PM
