1989 Other Oldsmobile Models Turn signals and Brake Lights
1989 OLDSMOBILE
CABBY49
Electrical problem
1989 Other Oldsmobile Models 6 cyl Two Wheel Drive Automatic
The car turn signals (left and right) work but the brake light on that side also flashes. The lens is a two color lens (amber and red) with two separate bulbs.The car will not pass inspection because they say the turn signal must flash and the brake light must remain on, the brake light cannot flash with the turn signal.
Apr 14, 2008 at 6:43 AM
MERLIN2021
  • 17,250 POSTS
If you look on the left side of the trunk, have a look at the wiring harness for corrosion or damage...also check the pigtail thats the light socket, for the same, and make sure you have the right bulb in the brake light pigtail!
Apr 14, 2008 at 7:23 AM
