2001 Oldsmobile Intrigue
2001 OLDSMOBILE INTRIGUE
198,000 MILES • 6 CYL • FWD • AUTOMATIC
WOLFMAN5878
I changed my serpentine belt but had to un-hook radiator reservoir to do so. Now my coolant light is on and my thermostat does not seem to be opening. I hooked the sensor to the resorvoir back up as well. Could i have somehow messed up the sensor and would that cause the thermostat to be non-functional? Somebody please help me!
May 27, 2010 at 8:02 AM
LEGITIMATE007
  • 5,121 POSTS
what makes you think the thermostat is not opening,? I think that because you unplugged it, it triggered the light, but will go off eventually once it goes thru whatever drive cycle it may need to. try unplugging the negative battery cable for a bout fifteen minutes and then see what happens, ecm, may need to do its component check again because it was unplugged, sensors I tell you.......
let me know what happens
jody
May 28, 2010 at 12:45 AM
WOLFMAN5878
thank you for your response. i was wrong about the thermostat. It is functioning properly but i will try the battery cable and let you know if it works. Thanx buddy
May 28, 2010 at 7:14 AM
