2000 Oldsmobile Intrigue Starter
2000 OLDSMOBILE INTRIGUE
137,000 MILES • 6 CYL • FWD • AUTOMATIC
DOCMARTIN000
  • 6 POSTS
I just bought this car, 3 days ago actually. It first started the other day when I started the car, but the radio wouldn't turn on, It finally did. Then I was driving it, everything was fine, and the blinkers wouldn' work, they finally did. Now The car won't start. I turn the keys, and the radio turns on, but you can't even hear the starter at all. I waited about an hour, and tried it again, it worked perfect. 5 hours later, it did the same thing, won't start. I'm afraid to leave my house and get stuck somewhere. before I take it back the the independent dealer and scream, I would just like your input. thanks so much!
Oct 19, 2008 at 3:33 PM
BMRFIXIT
  • 19,053 POSTS
1st step would be to check the starter,
and neutral safety switch on the tranny
I would suspect ignition switch if all tested ok
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 19, 2008 at 11:07 PM
