I suspect the engine coolant temperature sensor. It will need to be replaced, but you also must verify if the fan(s) come on when you turn the a/c and when the car gets over half way hot on the temp gauge, it may not be coming on when the temp gets high, then your problem may be the relay for the "radiator"fan not the a/c fan. Or both radiator fan and the engine coolant tem sensor
SPONSORED LINKS
Monday, August 9th, 2010 AT 1:35 PM
