Interior problem
1998 Oldsmobile Intrigue 6 cyl Front Wheel Drive Automatic 147K miles
My 1998 Olds Intrigue has the ignition switch mounted on the dash. I am not able to get the switch to go to the OFF position and therefore I am not able to remove the key. The car starts and runs just fine but since I cannot remove the key, the vehicle stays in what I believe is ACCY mode with the PRNDL position and the ODO illuminated. Since this first happened, I was only able to get the key out once out of a approximately 10 drive cycles.
Looking for some advice as to where to look for the problem.
Dec 13, 2008 at 7:48 PM
