1996 Oldsmobile Delta 88
1996 OLDSMOBILE DELTA 88
137,549 MILES • 6 CYL • 2WD • AUTOMATIC
MRSKAINE9
My car want start i think it mite be the starter,because it's done this before but it would start 10 mins after trying.The battery is in good shape .You can here a click when you turn the key,but the motor will not turnover.could you please tell what's a matter waith my car.
Jan 28, 2009 at 12:50 AM
MRSKAINE9
[quote:17d8877899="MrsKaine9"]Engine Mechanical problem
1996 Oldsmobile Delta 88 6 cyl Two Wheel Drive Automatic 137549 miles
My car want start i think it mite be the starter,because it's done this before but it would start 10 mins after trying.The battery is in good shape .You can here a click when you turn the key,but the motor will not turnover.could you please tell what's a matter waith my car.[/quote:17d8877899]
Jan 28, 2009 at 12:52 AM
DOCFIXIT
  • 18,828 POSTS
Think you are on the right track the click is solenoid but starter motor has a dead spot .Then new starter it is.
Jan 28, 2009 at 7:07 AM
