1992 Oldsmobile Delta 88 stalling
SHEETROCK
  • 1992 OLDSMOBILE DELTA 88
  • 6 CYL
  • 10,600 MILES
I have a 92 olds delta 88 royal the car stalls while turning either direction it has new fuel pump, cam and crank sensors, new ingition pack
Sunday, March 7th, 2010 AT 11:53 AM
LEGITIMATE007
  • 5,121 POSTS
Check /change the idle air control valve, if this doesnt help you may need a powersteering pump. Are there any check engine lights on?
Sunday, March 7th, 2010 AT 12:41 PM
SHEETROCK
There are no check engine lights on
Sunday, March 7th, 2010 AT 12:50 PM
LEGITIMATE007
  • 5,121 POSTS
Check the power steering fluid top it off if necessary, . With the posersteering resevoir cap off, and a friend nearby, start the car and work the steering wheel back and forth several times, to work out any air that might be in the system, then top off if necessary, see if its anybetter when turning corners, if not then go ahead and clean out the throttle body and throttle plate and check the idle air control vavle, could be dirty or faulty.
Sunday, March 7th, 2010 AT 12:56 PM
