1990 Oldsmobile Delta 88
MYCHA
  • 1990 OLDSMOBILE DELTA 88
1990 Oldsmobile Delta 88 6 cyl
My car jerks as I start to accelerate. What could be causing it?
Saturday, February 6th, 2010 AT 9:07 PM
Inspect and test all the following listed below:
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Cap and rotor
Note:If it doesn't apply disregard.
Sunday, February 7th, 2010 AT 12:32 AM
