Engine Mechanical problem
1996 Oldsmobile Cutlass 6 cyl Automatic
I have a 96 cutlass supreme came with 3.1L V6 with roller rockers. Unfortunately, the engine overheated and blew the top end. Question? Can a 91 Chevy Lumina with a 3.1L V6 engine and transmission be swapped out without to many obstacles. The only one I see so far is the tranny connection. Cutlass has a floor shifter and Lumina a column. Thank you for any information.
Oct 24, 2008 at 10:52 PM
