1995 Oldsmobile Cutlass Automatic
Is there a possibility that you can check the wear and tear of your cooling fan if the car is not running? I was told that the reason my fan put a hole in my radiator is because the bearings on the fan were going bad and it pushed against the radiator. I took the fan to the radiator shop and they didnt see any problems with the bearings.
SPONSORED LINKS
Thursday, July 31st, 2008 AT 11:30 AM
