1994 Oldsmobile Cutlass 6 cyl Front Wheel Drive Automatic
This car ran great until recently. It started having trouble starting up. We replaced fuel filter, spark plugs and cables, ignition control module, and had the plugged cadilactic converter cut out. What happens, is if it starts up, it sounds extremely rough, like it is not getting enough gas. If you can get it moving and rev it high enough by babying it, it will run great and run perfect until you shut it off and try starting it again. Once it has cooled down for hours, it can start again. It seems to have more and more trouble starting the more you use it in a given day. The problem is becomming more frequent now. We took it to the mechanic twice and it has been a waste of money. Any ideas?
SPONSORED LINKS
Monday, June 1st, 2009 AT 10:21 PM
