1994 Oldsmobile Cutlass Electrical
BILLWORL
  • 1994 OLDSMOBILE CUTLASS
  • 6 CYL
  • FWD
  • 170,000 MILES
My dash lights come on and the tranny doesn't work right I need to down shift to get goin also during this time the temp gauge runs hotter then normal. I thought it was a grounding problem so I cleaned the ground wires, any suggestions? Check engine light is one that doesn't come on. The fluid levels are good and the cooling fan works fine.
Wednesday, March 24th, 2010 AT 11:22 AM
LEGITIMATE007
  • 5,121 POSTS
Do you have a check engine light on?
Saturday, March 27th, 2010 AT 10:51 AM
LEGITIMATE007
  • 5,121 POSTS
That was stupid of me, check your fluid level(transmission). First of all. And verify that the radiator fan is working, as this helps to cool the tranny fluid.
Monday, March 29th, 2010 AT 10:32 PM
