1993 Oldsmobile Cutlass hey
SHERRIG26
Air Conditioning problem
1993 Oldsmobile Cutlass 6 cyl Front Wheel Drive Automatic
my airconditionong is coming through my defrost and not through my vents. what could be the problem? thank you
Jun 20, 2009 at 5:30 AM
  • 110,244 POSTS
The air is directed by vent doors that are actuated by vacuum. Chances are there is a vacuum leak under the dash or from the supply at the engine. Check under the dash first. With the engine running, you may hear a hissing sound to indicate there is a leak.
Aug 9, 2009 at 5:44 PM
