1992 Oldsmobile Cutlass car stalling out
JETHRO BODINE
1992 Oldsmobile Cutlass 6 cyl Automatic 100000 miles
I'm in need of a little guidance. A friends car (described above) will; warm up fine, drive (city) for 15-20 minutes then just die wherever it's at. After 5-10 minutes, it will restart and be fine for awhile, then die again.
When it is running, the engine sounds really good, no wierd sounds or idling patterns. No warning lights on the dash. With the engine shut off or running, there is fuel under (some sort) of pressure as evidenced by removing the protective cap on the fuel line inline bleed valve positioned beside the fuel rail and pressing on the valve stem.
They have had the car about 6 months (bought used, obviously). I'm unsure of the mileage on the odometer. The car quit on them last Saturday. Cost them $60 for the tow. Cost them another $225 for a new fuel filter, a new sending unit for the (radiator) fans, and a shrug of the shoulders from the mechanic.
I, haven't laid a wrench on it yet as I would prefer to get some knowledgeable feedback first. My skills are pretty good, my tools (diagnostic and all) are 350 mile away so I'm a little limited, but if it's fixable by backyard mechanics standards, then I'm pretty sure I can handle it.
Any help would be appreciated tremendously.
Thank you in advance,
Jethro B
Nov 21, 2009 at 7:03 PM
  • 110,246 POSTS
The first thing I recommend is driving the car till it shuts down, then checking to see (when it won't start) what is missing, fuel or spark. On this year car, there is a good chance the ignition module is bad. It is in the distributor. I think you need a phillips head screwdriver to remove it. REgardless, when it dies and won't restart, check for spark and fuel to the engine. Let me know what is missing.
Nov 28, 2009 at 4:55 AM
