1991 Oldsmobile Cutlass 4 cyl Automatic
I have a 91 oldsmobile cutlass cierra. At times the car will run great. But latly, I cant drive it for more that a few miles. I will start to stall and then die. I have to use gas and brake pedal @ stop lights or it will die. Sometimes it will start right back up & other times it wont. When it does start back up it will die again as soon as you put it into gear or barely touch the gas pedal. We have replaced the fuel pump, the air & fuel filter, the ignition module, and some of the censors. Can you please tell me what I need to do to fix my car? Thanks.
SPONSORED LINKS
Wednesday, May 21st, 2008 AT 3:56 PM
