1990 Oldsmobile Cutlass
SETH.CORDES
  • 1990 OLDSMOBILE CUTLASS
  • 6 CYL
  • FWD
  • 142,000 MILES
My emergency brake light is on after I stop the car then stays on till the car is shut off. Then turns back on after the first time I use the brake. What would be possible problems? Or more information you would like to know.
Wednesday, July 29th, 2009 AT 5:32 PM
BUDDYCRAIGG
  • 2,262 POSTS
How does the brake pedal feel?
The parking brake cable could need to be adjusted also.
Wednesday, July 29th, 2009 AT 7:03 PM
SETH.CORDES
  • 9 POSTS
I found the problem the brake line running to the rear brakes blew open.
Friday, July 31st, 2009 AT 2:13 PM
SETH.CORDES
  • 9 POSTS
I did the compression test 1- 98psi 2-100psi 3-102psi 4-99psi 5-100psi 6-101psi. That seems good I looked and it said all should be 100 psi. I had my tranny serviced and the car stays cool the temp light wont come on but when I shut the car off after driving for awhile it is boiling or bubbling in to the reserve coolant tank. What dose that mean?
Sunday, August 9th, 2009 AT 2:08 PM
BUDDYCRAIGG
  • 2,262 POSTS
Do a pressure test on the cooling system.
And also do a pressure test on the cap to make sure it's holding the correct amount of pressure.
Sunday, August 9th, 2009 AT 5:49 PM
