Engine hesitates and car loses power?
1988 OLDSMOBILE CUTLASS
103,000 MILES • V8 • 2WD • AUTOMATIC
AMM9G53N
At speeds above 50mph, the engine hesitates and loses power and the engine vibrates somewhat. Also, the engine loses a lot of power when driving uphill. I had the spark plugs and the gas filter changed, and also had the timing adjusted. But the problem persists?
Dec 15, 2007 at 8:01 AM
MERLIN2021
  • CERTIFIED EXPERT
  • 17,250 POSTS
Have the fuel pressure tested, the pump or regulator needs to be replaced..
Dec 15, 2007 at 10:49 AM
  • CERTIFIED EXPERT
  • 53,872 POSTS
Also, I would do a catalytic converter test because it sounds like it is clogged. Here is guide to help.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
This guide can tell you more on the engine low power problems, these are the most common ones which makes this guide great.
https://www.2carpros.com/articles/engine-has-low-power-output
Oct 10, 2024 at 5:01 PM
