1980 Oldsmobile Cutlass Cannot get v-belt on after removing
1980 OLDSMOBILE CUTLASS
100,000 MILES • V8 • 2WD • AUTOMATIC
OLDS80
My ac in my olds 80 cutlass has never worked. I decided to take off the compressor and other components of the a/c system. The compressor shared a belt with my air pump. The problem is, when I went to put a new v-belt on there isn't a tensioner or adjusting bracket to put the v belt around my air pump---water pump/fan---crankshaft. the adjustment was with the compressor. what can i do?
Mar 21, 2009 at 5:04 PM
2CARPRO JACK
  • 11,533 POSTS
Put the compressor back on unless it has a bad bearing on the pulley.Having it there, but not working isnt going to hurt anything, plus as you stated it is needed for belt adjustment.Only option is to find the brackets for a car without a/c and buy them and install them
Mar 22, 2009 at 1:53 AM
