Brake Lights don't work
BRITTANYNK
  • 1978 OLDSMOBILE CUTLASS
I have a 78 cutlass supreme and my brake lights don't come on when pushing on the pedal. They work when I turn on the hazards, and I've checked all the fuses and changed the stop light switch any other suggestions?
Monday, May 25th, 2009 AT 12:33 PM
JDL
  • 16,098 POSTS
Hello, did you check for voltage going to the brake switch? Orange wire, should be hot all the time. When the brake switch is activated, the white wire goes hot, runs to the turn signal switch. I believe your brake lites and turn signal use the same bulb filament, just not at the same time. You may have to look at the turn switch.
Monday, May 25th, 2009 AT 1:33 PM
MARIO ALVARADO
Belt diatgram v6 1978 oldsmobile supreme
Tuesday, March 6th, 2018 AT 8:42 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 49,912 POSTS
Please post your question here
Cheers, Ken
Thursday, March 8th, 2018 AT 12:40 PM
