1992 Oldsmobile Ciera
GOLDMAN09
  • 1992 OLDSMOBILE CIERA
  • 6 CYL
  • 10,000 MILES
Can dies while driving, you pull over it cools off then starts
Thursday, April 23rd, 2009 AT 6:52 AM
MMPRINCE4000
  • 8,548 POSTS
Generally when a car runs, gets hot and then dies, then restarts after cooling off, it is a bad ignition module. Most autoparts stores can test them, but I would replace it.
https://www.2carpros.com/forum/automotive_pictures/108325_ign_module_olds_1.jpg
Thursday, April 23rd, 2009 AT 7:11 AM
SJC1701
Had the exact same problem, same year vehicle. Drive 15 or 20 miles and it would shut off. Replaced the Crank Position Sensor (CPS). Solved the problem!
Friday, April 24th, 2009 AT 7:36 AM
Related General Content
