My old olds is a great car and in great shape but it has started to not run! when cold it starts great will drive untill warm then if you slow down to a stop engine will die, then is hard to start have to hold gas down like flooded but when it starts it will back fire and kick back against the starter if you get it started it won't pull its self is only running on two i think but back fires and dies if let idel. let it set for 4 hrs will start and run great untill you slow down then the same thing . won't start but back fires agains starter and if started runs on only 2 i think. help I love the old thing. Denis
Mar 30, 2009 at 1:45 AM
